markerline Posted June 28, 2005 Share Posted June 28, 2005 Dear users: I can't get Houdini to launch. It Segmentation Faults every time. This occured all of a sudden this evening. It was working fine before but when I shut down and rebooted a while later and tried to launch I got this error. What can I do to fix it? Any help is appreciated. Sincerely, penciline Quote Link to comment Share on other sites More sharing options...
edward Posted June 28, 2005 Share Posted June 28, 2005 Start up the Command Line Tools. In the DOS shell that comes up do: cd %HOME% move houdini7.0 houdini7.0.old If that doesn't work, maybe it's an environment variable. Quote Link to comment Share on other sites More sharing options...
markerline Posted June 28, 2005 Author Share Posted June 28, 2005 Start up the Command Line Tools. In the DOS shell that comes up do: cd %HOME% move houdini7.0 houdini7.0.old If that doesn't work, maybe it's an environment variable. 19100[/snapback] How do I start the Command Line Tools? I can't start a shell from within Houdini because it's immediately segment faulted. Should I do something from a conventional windows-shell? -penciline Quote Link to comment Share on other sites More sharing options...
edward Posted June 28, 2005 Share Posted June 28, 2005 Start menu > Program Files > Side Effects Software > Houdini 7.0.XXX > Command Line Tools. PS. We're on IRC right now ... #odforce at irc.freenode.net Quote Link to comment Share on other sites More sharing options...
markerline Posted June 28, 2005 Author Share Posted June 28, 2005 Start menu > Program Files > Side Effects Software > Houdini 7.0.XXX > Command Line Tools.PS. We're on IRC right now ... #odforce at irc.freenode.net 19102[/snapback] Thanks, that worked to move houdini7.0 to houdini7.0.old. Can anyone explain to me why this worked? Is it that my houdini7.0 folder became corrupt? -penciline Quote Link to comment Share on other sites More sharing options...
edward Posted June 28, 2005 Share Posted June 28, 2005 Yeah, looks like something got corrupted. You could try narrowing it down by removing the new houdini7.0, making a copy of the houdini7.0.old directory to be houdini7.0 and then slowly delete files until it comes back up again. Quote Link to comment Share on other sites More sharing options...
markerline Posted June 28, 2005 Author Share Posted June 28, 2005 Yeah, looks like something got corrupted. You could try narrowing it down by removing the new houdini7.0, making a copy of the houdini7.0.old directory to be houdini7.0 and then slowly delete files until it comes back up again. 19104[/snapback] Thanks, I'll try that. Glad to know I could get Houdini back up and running thanks to this forum. -penciline Quote Link to comment Share on other sites More sharing options...
