Most efficient way to save out result of copy sop?
Looking for a little help please. I've got 5 .ABC objects loaded and copy stamped. If i render the copy sop, i get memory usage of around 6 gigs ( what i expect).
If i save out the result of the copy sop ( rop writing an .ABC) then load and render the result, the memory usage is huge. What would be the correct way to save this out so that it renders efficiently when i load it back in?
Thank you,
Gbar
