classic shader core errors when connected to surface output
Hi all,
Am I missing something here? I connected the classic shader core to the surface_output but it just errors out. The input of the surface_ouput should be Cf but the classic shader core says Ce, what's going on here? Any help would be much appreciated.
Kind regards,
Quentin
Ce is Emission and doesn`t belong in the surface color. If you are using physical based rendering, just connect the yellow BSDF ports.
In case you are layering shaders, make sure to finish with layerunpack node and connect its F to the surface output.
http://www.sidefx.com/docs/houdini/shade/build#generating-outputs
Thanks for the reply! I'm not trying to do physically based or layer shading, just trying to get the classic shader core to output correctly. Are you saying I need to pipe the classic shader core to a layerunpack? The Cf seems to be missing from the outputs of the classic shader core.
Edited by Quentin Bellow
Got it to work using a Principledshader node piped into a computelighting node to the surface_output. I'm not sure what happen between Houdini 12 and 16, I've been mostly in other apps and am just coming back to it. But the classic shader core, according others, should be what I needed, but it doesn't have the outputs I'd need to connect it to the surface_output and I'm not sure why.
15 hours ago, konstantin magnus said:
If you connect all four outputs of the classic shader to the computelighting inputs, what are you missing?
Aha! You are correct, however, before your original reply I didn't know about the computelighting node. Flew over my head yesterday. Thanks for the help :)
