Imatk Posted March 24, 2017 Share Posted March 24, 2017 Just getting into Houdini and have run through a few tutorials. I'm looking at the shelf dynamic DOP network for rigid bodies and in the network for both static and active there is a merge between the object node and the solver node. I'm just curious... why is that needed? It appears to work without them so I'm just wondering why they were added. Thank you Quote Link to comment Share on other sites More sharing options...
haggi Posted March 24, 2017 Share Posted March 24, 2017 If the merge node only has one input, it is not needed. The only advantage of the automatic creation is that you do not have to create it manually in case you want to add some inputs. Quote Link to comment Share on other sites More sharing options...
Imatk Posted March 24, 2017 Author Share Posted March 24, 2017 Cool thank you I'm just trying to get my head around the nodal networks so I wasn't understanding why they were there. Quote Link to comment Share on other sites More sharing options...
