Volume From Attribute SOP node question
http://www.sidefx.com/docs/houdini/nodes/sop/volumefromattrib
I am looking at "Volume From Attribute SOP" node, and I understand that it samples points attributes and "move" them to Volume fields. There is an "Attribute" Parameter that says which point attribute to copy from (e.g. vel attribute defined on points), HOWEVER , I don't see any volume parameters that tell where to paste the copied attributes to (e.g. a volume might have vel1 and vel2 attributes, so which one gets vel)???
volume_from_attribute.hip
