Guide Geometry
What do I need in cookMyGuide1 just to get the geometry from an input to be displayed unaltered?
The only example I can find is in Flatten.C and that creates it's own guide geometry.
I thought all you would need to do would be to duplicate the appropriate source just as you do with cookmysop using
duplicateSource( 1, context );
but that doesn't appear to work.
I also thought perhaps I don't need to do anything since Houdini would by default just draw the inputs as guide geometry.
But that doesn't work either.
Any pointers?
1 line or pages either is good. :)
I don't think duplicateSource will work because it is used to copy into the gdp pointer -- but a good guess though :)
Try:
GU_Detail *in_gdp = (GU_Detail *)inputGeo(1, context);
if (in_gdp)
   myGuide1->copy(*in_gdp);
In the cookMyGuide1() method after you lock the inputs.
Hope that helps.
George.
