a popsprite question about Rotate.
I created particle from shelf "Location Particle Emitter"  and added sprite from "Sprite Particle" in the shelf.
The sprite Map is default smokepuff .rat
I have been trying to rotate the displayed sprite around the view axis by using 'rotate' parameter.
But it looks like scaling height/width every 90 degrees.
ig: rotate 0(original Shape) >> rotate 30 (looks scaled down width) >>rotate 45(completely scaled down to 0 that disappear from screen) >> rotate 90(original shape).
How can I make it works correctly?
I had tried on H15.5.565 and H16.0.504.20 but same result.
Edited by jhcl21
  • 6 months later...
Same as me.The "rotate" parameter works just as you wish in Houdini FX 15.0.360.But when i open the same project in higher version it appears like the image you've showed.I believe something has changed inside the node,but i got no solution either.
