Two VDB questions
[Still one questioned unanswered, plz help me answer it :) ]
I am rendering pyro simulation in an external renderer that reads VDB, hence I export pyro as VDB (using convert VDB node). I have the following two question:
-Is there a way where I can see the value ranges of "Heat" calculated? Meaning, min heat is 5.0 and max heat is 20.0? I need to know the max/min ranges in order to tune the rendering parameters...
-The external renderer reads "Temperature" to render fire, however Houdini uses "Heat" instead, so my question: how to rename "Heat" to "Temperature"? [SOLUTION: just add primitive wrangler and type s@name = "new_name"]
Thanks,
Edited by catchyid
