Re-group broken pieces into an object
Six_Lin
Hi there, There was an effect i'm interested to. And I try so hard to simulation it, But I'm feel so confuse about that.
In the commercial video , around 6s-8s , there are pieces rocks on the ground and roll or stick together to be a shape of phone.
I try to do the same effect in houdini , I shattered an object then do a rigid body and let it collapse on the ground , then cache the result and reverse it.
But, It look like time reverse but not like what I was think about.
I've researched lots of keywords but still can't work , maybe someone can give me some tips about this.
  • 1 month later...
Simply take a timeshift node after your sim. On the first frame of your sim keyframe the frame parameter of that node to the end frame of your sim. On the last frame of your sim, keyframe the frame parameter of the timeshift node to the first frame. Done.
