Art Directed Wall Explosion
renderedhero
Hey everyone,
I'm trying to blow an object through a wall. I need a lot of control over the art direction. I have been doing my look dev in C4D where I can paint active vs passive objects. I can also have the active objects asleep until there is a collision detected.
I have attached my working Houdini file. I haven't been able to figure out to paint active vs passive objects, so my workaround has been to alter the glue strength based on a color attribute that I created in the constraint network. This seems to work okay, but the wall get's knocked over when the collider goes through it. How can I pin this wall down to the ground? The tuts I've found all seem outdated for H16.
Any help is most appreciated. Thanks!
-Brian
WallExplo_Help.hiplc
