Render Points
  Bernard said:
Hello,
How can I render points in Houdini. I want a lot of points (no spheres)to make water spray.
Thx
19209[/snapback]
there a couple of ways u can render points
going to the render tab of the obj, and setting the
geometry > render only points
OR
if u using pops, then attach a render pop, and u can set the radius
or u can amend a "attribcreate" sop and add a "pscale" variable on point type, and that will scale ur particles to fill ur needs
all the best
aracid
OR
all the best
aracid
19219[/snapback]
Wonderfull, thanks!
bernard
