extruding faces per primitive
alexcapan
I'm trying to control the extruded distance per primitive of the sphere.
I have the values that I want which will drive the extruded distance of each primitive. It's labeled extrudeHeight in the geometry spreadsheet.
To do this, I'm using a primitive wrangle where I will store the height values into zscale and then use the local control on the polyextrude node to override the distance using zscale.
For some reason this isn't working as @extrudeHeight seems to return 0. I was wondering if someone knew a way to do this. It doesn't have to be through an attribute wrangle I really just want this thing to work.
Many thanks in advance for any help! :D
