surface constraint question
dedeks3000
Hie everyone,
I'm using the surface CHOP constraint ,with mode set on Closest Distance , it works well but it only output xform SRT channels and i need the resulting uv position on the surface,
I' ve found a solution but too complicated to setup.(SOP + expr + ....).
Did someone know how to do it in CHOP ?
Thanks
