Copy to Points
Hi...  New Houdini 16 user here......
I've created a randomized set of balls in the viewport with a scatter. But, when I do a copy to points, all of the balls are the same size... Is there a way to have random values (with a clamp or fit?) to alter the size of the balls?  Tried putting a random on the uniform scale on the transform before going into the copytopoints, but...all are changed to the same value.
I'm sure I am doing something silly...did some googling / documentation review, but I might not be asking the correct question.  Thanks.
teak
Add a pscale attribute to the points before they go into the copy. This will be automatically recognized by the copy to points node.
That will scale each copy by the value of pscale.
You could use this expression in a point wrangle:
@pscale = fit(rand(@ptnum), 0, 1, 0.3, 2)
Where the last two numbers are the range of the pscale value
Thank you for such a quick reply...
In my geo spreadsheet on the attrwrangler I do see the random value of the pscale, but on the copytopoints, the pscale value is 1.0.  Did I miss something?  Thank you again for your help.
teak
