Dopnet Creates a Duplicate Pyro object
MrBrN197
Hi, I seem to be having a problem where my dopnet creates two pyro objects with the exact same name and attributes (I don't mean an actual node I can just see it on the Geometry spreadsheet it has the same "unique id" and all the same property-value pairs). When I use a dopimortfields to bring in the data to sops. I get two of each field(density, density, vel.x,vel.x and so on). I feel like the problem is related to the initial state parameter because I had some trouble with getting that to work with explicit caching and that's when the problem seems to show up even after I eliminate the initialstate file the scene is just permanently displaying that there are two pyro objects in the dopnet. Has anyone ran into a problem like this. Is there a way I can manually delete data on the geometry spreadsheet through the dopnet.
Also just to add when I import the fields they don't necessarily have the same resolution. some insight on the way dopnet objects work would be very helpful.
  • 3 years later...
