Questions about Houdini Primitives
http://www.sidefx.com/docs/houdini15.5/model/primitives
I notice when I middle click on a SOP geometry (e.g. Sphere, Box,...) , I find the number of primitive equals the number of polygons, nurbs, volumes, etc. From the documentation, I understand that a primitive is like a super type that could further defined by sub types such as polygons, nurbs, volumes.
My questions
-would be always that the number of primitives equal the number of polygons/nurbs/vdb/?
-why even bother mentioning the number of primitives?
I am sure there is a difference between a primitive and its sub-type, but I don't have an example to show me the difference...
Thanks
Yes Sir :) Well, I did couple tests as you suggested and the only difference I see is that "primitive" specifies the total number of "geometrical units" in the node, and it's further classified as sub geometrical units : polygons, nurbs, VDBs, etc. Meaning, there could 3 "primitives" = 1 "VDB" + 1 "Nurb" + 1 "Polygon".
Why it's strange? As far as I understand it, it says: there are 290 primitives ("geometrical units" using Houdini Docs), which are broken down as : 288 polygons + 1 Nurb + 1 Packed Geo (total is 290, which is the same number of primitives) ?
Guest tar
 A primitive is a 1st order summation whilst the next is a second order. i.e. more detail. I guess I'm not understanding the original question.
I don't understand your definition of 1st order and 2nd order :) I think I got my own little definition of primitives here, I will stick with it until I find a situation where it's broken, then I will ask more specific questions :) Thank you for your help and time Marty :)
