davedjohnson Posted July 22, 2005 Author Share Posted July 22, 2005 Ok, I see that. I think I saw a function that checks three points to see if they are collinear and returns an int. Quote Link to comment Share on other sites More sharing options...
edward Posted July 24, 2005 Share Posted July 24, 2005 I'd be interested in the qhull stuff, been looking out for it for a while. Any chance of a link or better yet the code... 19703[/snapback] Ok, download the qhull 2003.1 source from here: http://www.qhull.org/download/ Replace io.c from the one found in the attached archive. Compile. Thereafter, using qhull's -o option will output .ply files which one can read into Houdini. qhull_2003.1_ply.tar.gz Quote Link to comment Share on other sites More sharing options...
sibarrick Posted January 6, 2008 Share Posted January 6, 2008 You missed the thread I posted about chull. The only reason why I used the GPD is because I don't have MSVC at home and thus have been compiling using MinGW. GPD is the public domain version of the $GEO library. So basically, it's a cinch to integrate chull into a SOP if you want to. Hi Edward, Where does one find this public domain geo library? I want to write a commandline program that reads geo files, so i can run it using the unix sop, I only really need triangles so I could write my own but this sounds like it might be useful. Quote Link to comment Share on other sites More sharing options...
edward Posted January 6, 2008 Share Posted January 6, 2008 Unfortunately, GPD is no longer publicly available due to disuse over the years. Although conceivably, someone could make it opensource and have it community supported. It's not a small undertaking though. EDIT: It's now available here: http://sourceforge.net/projects/houdinigpdlibra/ Quote Link to comment Share on other sites More sharing options...
