Convex hull Node works no with flat surfaces like Grids?
From what I can see, the convex hull node doesn't work with flat surfaces like grids. As soon as I pick a random point and move it slightly in Y, it works. Is this a bug?
Edited by schiho
Yeah, also found this out at some point. Although it sort of makes sense, as a flat plane is not a convex shape.
You probably just want to use a Triangulate2D in this case ;)
Edited by acey195
