How to use len() ?
So here's a simple index array on which I try to get the lenght of in Attribute Wrangle. But it throws an error like it wants vectors, so I'm left wondering if this is the right function to use or the code is missing something.
Thanks.
  On 6/7/2017 at 10:52 PM, sadhu said:
There is one more function called  arraylength that returns length of an array
Expand
That one is deprecated now though, use len() instead, in the way dedeks put it.
the "i[]" prefix to @ is just a way to cast the attribute as an integer array.
the "Ambiguous Call" warning that you get basically tells you that you need to be more specific.
see this page:
http://www.sidefx.com/docs/houdini/vex/snippets
(about 1/3rd to halfway down the page)
Edited by acey195
Thanks guys, indeed when reading mestela's wiki I've noticed him saying he always forgets to initiate them and I didn't get it at the time, because I thought it only meant for new attributes, not custom ones which signature is not well established.
  On 6/8/2017 at 8:08 AM, acey195 said:
see this page:
Expand
Cheers!
  On 6/7/2017 at 6:57 PM, dedeks3000 said:
I must admit that houdini and arrays it's a big story.
Expand
Yeah I'm wondering if I'm going the right path with my approach. Also with the fact from what I can see, you have to go outside VOP or Attribute Wrangle to change the context of data (point, vertex, prim, detail) is a bit disheartening.
Edited by probiner
  • 4 years later...
Old topic but.. I could never have figured this out.. I always thought that once an attribute type has been initiated we don’t need to specify it again so as to assign or modify that attribute later.. But I guess arrays are totally different!
Thanks
Edited by sush2911
