johnLIC Posted June 20, 2017 Share Posted June 20, 2017 I'm trying to make an ocean surface about 10 meters across, with a quiet feel. I'm having trouble making waves that have peaks without a lot of higher frequency displacement. How can I get waves that are peaked but not lumpy? I need to export displacement maps to be rendered outside of Houdini, so I don't have the advantage of the Houdini ocean shader. I think I've got enough resolution in my maps (3000 x 3000). When I try to filter out the lumps I lose the peaks and it looks like a rubber sheet. Quote Link to comment Share on other sites More sharing options...
fuat Posted June 20, 2017 Share Posted June 20, 2017 just a thought: - with a grid of 10x10, set ocean spectrums "resolution exponent" to something like 10 or 11. - on you ocean evaluate, set downsampling to a higher value like 3 or 4 - if waves too fast, lower ocean spectrums "timescale" this should help i think. Quote Link to comment Share on other sites More sharing options...
johnLIC Posted June 21, 2017 Author Share Posted June 21, 2017 I'm having a go at it, but downsampling 3 or 4 results in that quilted, square patches look. I'm just having a hard time imagining how it's going to work conceptually. If I could gamma the map so the high values are higher, that might make the waves crisper, but I'm not sure how to do that between the ocean spectrum and the ocean evaluate. I'd like to do it to the output .exr map in Nuke, but my non-commercial license only outputs 1920x1080... Quote Link to comment Share on other sites More sharing options...
johnLIC Posted June 22, 2017 Author Share Posted June 22, 2017 The chop needs to be tuned according to the scale ("ampscale"). At lower scales it takes more chop to get peaks. Quote Link to comment Share on other sites More sharing options...
timfagan Posted June 23, 2017 Share Posted June 23, 2017 Have you tried using the 'Filter Above Resolution' on the ocean spectrum node? You can clear away those higher frequency waves by setting a lower value. Quote Link to comment Share on other sites More sharing options...
