clouds...
evanrudefx
Hey,
What is a good way for creating large masses of clouds? I tried using the regular cloud node, but it seems really slow. At large scales it seems to run too slow to have a high enough resolution. I am trying to do something similar to this, just covering a bigger area. Any suggestions?
I found the problem. View port limits the resolution on 3d textures, and I did not realize it. So I was cranking up high values. After turn off texture limit, I can actually see my clouds fine.
Edited by ejr32123
