UpyopyoSky Posted June 22, 2017 Share Posted June 22, 2017 (edited) Hi, I am a very beginner of coding and looking for a custom save shell by python. This time, especially I'd like to ask for how to replace ".comment." part. Example file is "fx_dest_vocity_v051.04.comment.hip" and a procedure is : 1 - click shelf dock 2 - show a popUpWindow and type a comment 3 - click the popUpWindow, close it, and a script replaces "comment" part and new file name is saved, for example, "fx_dest_vocity_v051.04.vel2xfaster.hip" my best guess is; fileName = hou.hipFile.basename() ## for instance, file name is "fx_dest_vocity_v051.04.comment.hip" hou.ui.displayMessage("type comments", variable ) ## save comment hou.ui.displayMessage.close result = re.search( "([0-9]{2})\.???????\.hip", fileName ) ## get comment part newFileName = fileName.replace( result.group(1), variable ) hou.hipFile.save(newFileName) ## new file name "fx_dest_vocity_v051.04.vel2xfaster.hip" I know it's so many broken lines, so if someone helps to rewrite it, it would be great, thanks! Edited June 22, 2017 by tagosaku Quote Link to comment Share on other sites More sharing options...
f1480187 Posted June 22, 2017 Share Posted June 22, 2017 I think your "mock script" will work as designed, with minor edits. Always use raw literal before regexes in Python: r'^(.+)\.(.+?)\.hip$'. Otherwise you have to escape each regex backslash with another backslash. 3 hours ago, tagosaku said: if someone helps to rewrite it, it would be great Ok, here is how I would do it myself. Notes: 1) it doesn't required for an addition to be the word "comment" here; 2) for simplicity, it does not perform any error check: assume proper use or add extra if statements. import os.path as op import hou # Fetch tuple with index of pressed button and input text. choice, text = hou.ui.readInput('Type comments message', help='Type comments description.', title='Commented HIP', buttons=('OK', 'Cancel'), default_choice=1, close_choice=1) # If OK was pressed with some non-empty text. if choice == 0 and text: path = hou.hipFile.path() dir, name = op.split(path) # Discard extension. name = op.splitext(name)[0] # Discard one '.anytext' occurence at the end. name = name.rsplit('.', 1)[0] # Make new name with input text. new_name = '%s.%s.hip' % (name, text) # Finally, create an absolute path to save file to. new_path = op.normpath(op.join(dir, new_name)) # Save the file. #hou.hipFile.save(new_path) print(new_path) # TEMP: print to console instead. Quote Link to comment Share on other sites More sharing options...
UpyopyoSky Posted June 23, 2017 Author Share Posted June 23, 2017 F1, thanks for your quick reply. Whole codes are changed and I can understand 70%. That's ok, and I tried your code and working well. I would like to ask for two things, When typing comment and hitting 'enter key', it executes as cancel, but prefer to execute as 'ok'. Then I changed to default_choice=1 Is that correct approach? Second questions, Actually I want to sometimes add comment words, not always. For instance, sometimes name "fx_dest_vocity_v051.04.comment.hip" or "fx_dest_vocity_v051.04.hip" Then I tried to change your code, but messed up. (sometime it loses last two digit numbers in a condition...) Could you add the feature that I can save a file with blank text? Quote Link to comment Share on other sites More sharing options...
f1480187 Posted June 23, 2017 Share Posted June 23, 2017 (edited) 1. Choice nums relate to the buttons tuple: ('OK', 'Cancel'). 0 is 'OK' and 1 is 'Cancel' here. 2. You can accept cases where text not entered and omit name changing part if there is no text entered: if choice == 0: path = hou.hipFile.path() # Replace existing comment. if text: dir, name = op.split(path) name = op.splitext(name)[0] name = name.rsplit('.', 1)[0] name = '%s.%s.hip' % (name, text) path = op.join(dir, name) path = op.normpath(path) # hou.hipFile.save(path) print(path) Personally, I would just normally save with Ctrl+S. 3. By the way, if you use the code as a shelf tool, you have different ways of invoking it: click, Ctrl+click, etc. Try printing kwargs dict available inside shelf tool script and inspect contents. You can check if the shelf was clicked with modifier button to bypass dialog window. Edited June 23, 2017 by f1480187 1 Quote Link to comment Share on other sites More sharing options...
