VORONOI & REM -ADD FRACTURE POINTS
Brickouz
Hello!
I would like to know how you could control how your voronoi or fem will break. I used to watch videos by Sangiemenla, he explained how to use the "add" node to control where your solid would be fractured. But now I can't find his channel any more and I can't remember!
I would also like to know if there is a similar way for FEM network, to set where the solid object will break.
Thank you!
Antonin
It's OK, I found out! You just have to put another solid inside a scatter node, so this solid will define how your initial object will fracture.
Since I opened this thread, I have two more questions about the same topic. First, like on the video I uploaded, the collision object can flicker then the fracture gets weird. Is there a solution to this?
Second, I did not manage to use the RBD glue object right. The voronoi objects just breaks itself, whatever I do. Can I do something about this?
Thank you again!
colli bug.mov
