OpenCL Wrangle COP: Image Manipulation on the GPU using OpenCL
animatrix
This operator allows you to run an OpenCL kernel as part of your COP network. Depending on the GPU, some operators can be orders of magnitude faster than even VEX.
In this case OpenCL is 192 times faster than VEX on GTX 970. Please note that the actual cooking time for the VEX node is much longer (~77s for 100 iterations vs 40s for 10000 iterations) than what the status bar is showing. The cooking timer is shown long after I set iterations to 100 as can be seen in the video.
  • Like 5
