Two RBD packed constraints 1) Spring to keyframed World Space Position 2) Spring between adjacent pieces
ikoon
Please see the attached image. Attached is also the hip file I made by following this, https://vimeo.com/97640407 from Peter Quint, but it is not on packed rbds.
I can do the classic packed rbd, connect adjacent pieces, set the constraint network and relationship.
I dont know how to:
 - get positions from the individual Packed Objects
 - set those positions to the individual Anchors: Object Space Position
 - merge Constraint Network with Apply Relationship
I would like to understand it. Could you please direct me?
Also, please, I dont know how to debug in DOPs. In SOPs, I can print to console, make additional attributes in SOPs and watch them in the Geometry Spreadsheet. Would you please share some tips, related to this issue?
constraints.hiplc
Edited by ikoon
Not 100% sure what you want, but I rebuilt your scene using constraint networks and packed prims. Now there is one spring network which follows the points, and another that attaches them to each other. I find Apply Relationships tricky to use, so I don't use it.
If you go inside the anim_points node, there are two red nodes inside. In them are the strength, and the damping controls for the two spring systems.
The yellow lines are the constraints.
constraints.hiplc
