expose edges with dirt mask (convex curvature)
Hey all, I'm using houdini 15.5 and I'm trying to expose edges (in a manner similar to vray curvature/ inverted ao- https://docs.chaosgroup.com/download/attachments/12085592/VRayCurvatureHero.png?version=4&modificationDate=1487005362000&api=v2), the manual says "If the negated normal is connected, will find exposed edges. @parameters" so I took global variables, took the P plugged it into the P, took the N and added negate node (also I tried multiply constant with -1 instead) and plugged it into nN, the bias direction is 0, 0, 0, and still all I'm seeing is occlusion dirt, same as with default settings.
I know that there's a 'curvature' VOP, but it yields some weird results for me, so I would like to try the dirt instead and see if it's different, so please help:)
I think your setup is simply wrong somewhere, it should work as described. Post scene. Bias should place ray starting point above a surface. Try to scale your negated normal by a small value and use this as bias.
Curvature mask produces better results than occlusion masking, but meshes must have a nice curvature, therefore be smooth.
worn_edges.hipnc
worn_edges.hipnc
cool, I'll try that, thanks!
