defc0n1 Posted July 2, 2017 Share Posted July 2, 2017 Hi guys Here's my problem - I need to work with openVDB volumes and I need to code using a python node. The problem is, even after successfully installing openVDB, I am not able to import the pyopenvdb module in Houdini. I can access it from the shell in my Mac, and can create/manipulate volumes etc., but not from Houdini. When I try import pyopenvdb as vdb in the python node or shell, it just says that it cannot find the module. Please help. Thanks. Quote Link to comment Share on other sites More sharing options...
