Sumatra Posted July 3, 2017 Share Posted July 3, 2017 When I add one arnold light in the scenes,some erro message attack,I can not understand what is wrong?please give me a help,thanks! Traceback (most recent call last): File “opdefObject/arnold_light?PythonModule”, line 1, in <module> File “CUsers/Administrator/htoa/htoa-2.0.0_r240c4dd_houdini-16.0.557/htoa-2.0.0_r240c4dd_houdini-16.0.557/scripts/python\htoa\ipr.py”, line 15, in <module> import psutil File “CUsers/Administrator/htoa/htoa-2.0.0_r240c4dd_houdini-16.0.557/htoa-2.0.0_r240c4dd_houdini-16.0.557\python2.7libs\psutil\__init__.py”, line 113, in <module> from . import _pswindows as _psplatform File “CUsers/Administrator/htoa/htoa-2.0.0_r240c4dd_houdini-16.0.557/htoa-2.0.0_r240c4dd_houdini-16.0.557\python2.7libs\psutil\_pswindows.py”, line 14, in <module> from . import _psutil_windows as cext ImportError: DLL load failed: Houdini 16.0.600 arnold 2.0.0 Quote Link to comment Share on other sites More sharing options...
Martin47 Posted July 3, 2017 Share Posted July 3, 2017 "File “CUsers/Administrator/htoa/htoa-2.0.0_r240c4dd_houdini-16.0.557/htoa-2.0.0_r240c4dd_houdini-16.0.557\python2.7libs\psutil\_pswindows.py”, line 14, in <module>from . import _psutil_windows as cext" seems like a mismatch in the Arnold/Houdini builds version, if you check the Solid Angle documentation explicitly said: "The HtoA build must match exactly your Houdini install, down to the build number, or random crashes and glitches will occur. Quote Link to comment Share on other sites More sharing options...
Sumatra Posted July 4, 2017 Author Share Posted July 4, 2017 Thank you !But Ny builds version is same with houdini version Quote Link to comment Share on other sites More sharing options...
