FEM error when using target objects and fractureing
gramx
I am doing some more FEM testing and have found that if you are using a target object then you can't use solid fracture as well without pieces jumbling up. Anyone know a way of fixing this. I have attached an example scene, if you enable fracturing on the solid object then you will see what I mean.
Thanks
Graham
FEM_break.hip
Edited by gramx
