Hair Density Painting and Adjust Length
Hello,
I have 2 questions about the hair:
1. When I paint the density attribute the hair guides are reacting based on the vertices, i.e. when I hit only a vertex guides disappear (or appear). It means that with low polygon count I can't avoid stepped guides boundary. But with more subdivisions it is practically impossible to work due to long cooktime after each brush stroke… How can I deal with the guides between the vertices without increasing subdivision? Attachment below describes it.
2. To delete hair guides (for example, for hairline or beardline on the head) I use Length Adjust shelf tool with Target Length value of 0.001 (complete 0 is impossible), but this still leaves hairs roots as dots when rendered. Is there a cleaner way to delete the hair neatly along the boundary?
  • 2 years later...
