ikoon Posted July 19, 2017 Share Posted July 19, 2017 Please, how to follow path and auto-bank now with the new H16 constraints? In H14 we had the Auto-Bank factor, which controlled the automatic banking of an object as it turned corners.For now I just revealed the old interface in H16 (it is just set invisible)https://www.sidefx.com/tutorials/motion-path/ Quote Link to comment Share on other sites More sharing options...
ikoon Posted July 22, 2017 Author Share Posted July 22, 2017 Here is a VEX solution. Attributes are then on the path. So we can use the Look Up Mode: Up Vector Attribute from Path. Thank you Javier Toledo! Btw the fourth inputh on the Follow Path CHOP is still a bit of mystery for me. I was hoping I could use some lag/jiggle chops also. I will investigate. 1 Quote Link to comment Share on other sites More sharing options...
friedasparagus Posted August 12, 2017 Share Posted August 12, 2017 Hey ikoon, That fourth input on the Follow Path CHOP is a funny one... it seems to accept channels named "roll0" and "pos0" and will use them to override the position on the curve and the roll. Either one can be present or not and the other will still work (i.e. one channel named "pos0" will still work without accompanying "roll0" channel) 1 Quote Link to comment Share on other sites More sharing options...
ikoon Posted August 14, 2017 Author Share Posted August 14, 2017 Nice! Thank you! Probably we are still forced to wrangle the up vector "manually"? Is there any CHOP trick? Any Slope CHOP analysis on 3D? Curvature Analysis SOP is not enough. I have attached a file, which solves the up vector with Javier's method. It may be helpful for somebody in the future. Thanks go to Javier. follow path - v0.hiplc 2 Quote Link to comment Share on other sites More sharing options...
friedasparagus Posted August 14, 2017 Share Posted August 14, 2017 Hi again... Just had a little play with moving more of that method into CHOPs... It is not finished by any means (try moving part of the path off the ground plane and watch the polyframe go mental!) but maybe it might give you some ideas... Another note is that the channel wrangle in the chopnet is completely unnecessary, it just felt cleaner to me that two math nodes and a slope! I'll certainly be revisiting this, I'll let you know if I get anywhere Cheers, Henry follow_path_chops.hiplc 1 Quote Link to comment Share on other sites More sharing options...
Toledor Posted September 26, 2017 Share Posted September 26, 2017 Hi guys. I'm glad you found it useful. Banking with constraints is great but it's also nice to create it in sops so you can use it for modeling. I'm also getting used to the new constraint system. Slow and steady =) Quote Link to comment Share on other sites More sharing options...
