nomadiclove Posted July 25, 2017 Share Posted July 25, 2017 help ! RBD use autofracture the transformpiece not work!!!! make_transformpiece.hip Quote Link to comment Share on other sites More sharing options...
nomadiclove Posted July 25, 2017 Author Share Posted July 25, 2017 Is there someone can solver the problem???? Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted July 26, 2017 Share Posted July 26, 2017 have a read - fighting it myself.. Quote Link to comment Share on other sites More sharing options...
nomadiclove Posted July 27, 2017 Author Share Posted July 27, 2017 9 hours ago, anthonymcgrath said: It is different situations.... the numbers of debris is change every frame. Quote Link to comment Share on other sites More sharing options...
adrianr Posted July 27, 2017 Share Posted July 27, 2017 I'm not 100% but I don't think you can use transform pieces in this situation. You're getting out more points from DOPs than you're putting in. Transform pieces expects a matching point count (well, technically this can work without it as you'll see in Anthony's thread, but it's not ideal) and a matching name attribute. If you're trying to move 20 initial chunks based on 40 points coming from DOPs I'm not sure how you expect that to work? The geometry being made in DOPs doesn't exist pre-sim in SOPs. Quote Link to comment Share on other sites More sharing options...
