Carbon fiber cloth with single peaces
Hi
I have to work on and animated piece of cloth where the individual square pieces are docking into the animation.
How would you go about the rendering? I got an attribute that separates bright pieces from the dark ones. Can call that attribute into the shader but need more variation. Would you use a for each loop to iterate over each piece in order to apply e.g. individual uvs for each piece? The material should be very sparkly on some parts.
