bamine Posted November 20, 2002 Share Posted November 20, 2002 Hi Guys, I am having a problem with Roudini and Redhat8.0. I guess my install went fine. When I execute "houdini", I get the initial logo, then suddenly it dies. here is the sequence: <sequence> cd /usr/hfs5.5 csh source houdini_setup cd bin houdini </sequence> I am doing something wrong? if the answer is no, is there any debug level that I can turn on, or a log that I can have a look at? (sorry guys, I am new to Roudini ) Thanks Amine Quote Link to comment Share on other sites More sharing options...
miguel m Posted November 21, 2002 Share Posted November 21, 2002 Stremik, did you try www.redhat.com/mirrors ? At least my local mirror here in Spain has every version from 6.2 up to 8.0 bamine, do you have a 3d accelerated x-server installed? try anything that uses opengl like the xmms opengl visualization plugin, if it runs strangely slow and ugly or doesn't run at all, you got trouble there. Or maybe (I'm not really sure about this one but should work) try setting the variable HOUDINI_OGL_SOFTWARE to 1 before launching houdini. By default redhat installs mesa libraries that can run opengl in software mode. This can be very slow so just try it for troubleshooting. in a bash shell export HOUDINI_OGL_SOFTWARE=1 in a csh shell setenv HOUDINI_OGL_SOFTWARE 1 Quote Link to comment Share on other sites More sharing options...
bamine Posted November 22, 2002 Share Posted November 22, 2002 Thanks miguel, I tried setting the HOUDINI_OGL_SOFTWARE to 1, but it did not work. I do not have xmms paxkage installed. What I have noticed is that, when I check the processes that are up, after the I tried to start houdini, I see that there is a "hserver" up, but with 0 CPU activity. SO, if I am understanding it correctly, there is no debug or verbose mode that can help debugging? Any idea will be appreciated Amine Quote Link to comment Share on other sites More sharing options...
danteA Posted November 22, 2002 Share Posted November 22, 2002 Does hscript work? Quote Link to comment Share on other sites More sharing options...
