VEX array of structs
demian
Hello,
I'm a newbie with vex and I'm trying to create an array of structs. In my wrangle node I defined the struct in the outer code section as suggested here
my struct looks like this:
struct node {
    int pt;
    int nbrs[ ];
In my code I later declare
node nd;
node array[ ];
I manage to initialise the nd variable normally. Then I tried the following
  1. int pt = nd.pt; //works fine
  2. int nbrs[] = nd.nbrs; //works fine
  3.
  4. array[0] = nd; //seems to work fine
  5. pt = array[0].pt; //nope
  6. nd = array[0]; //nope
By doesn't work I mean that the node turns red saying the following
Error
The sub-network output operator failed to cook: /obj/new_version/tree/growing_alg/find_neighbour/outer_code/attribvop1
Warning: Errors or warnings encountered during VEX compile:
/obj/new_version/tree/growing_alg/find_neighbour/outer_code/attribvop1: Internal compiler error. (15,1).
Error: Vex error:
Failed to resolve VEX code op:
Unable to load shader 'op:/obj/new_version/tree/growing_alg/find_neighbour/outer_code/attribvop1'.
Warning
Warning
Warning
Vex error: /obj/new_version/tree/growing_alg/find_neighbour/outer_code/attribvop1: Internal compiler error. (15,1)
Any ideas?
Thank you
Marta
  • 1 year later...
This was frustrating but found the issue. Posting it here since it looks like the vex compiler bug hasnt been fixed:
looks like a vex compiler bug
traced it down to you have to make your custom structs be defined before the first call to len() although it probably holds for any array functions
so ended up having to move all base custom structs into a base header file with no references to any array functions
