leohak Posted August 8, 2017 Share Posted August 8, 2017 hello! probably a simple mistake but here I go. I'm trying to recreate the following effect and can't get the rotation from the points to the small objects can you help me? overgrowth.hipnc Quote Link to comment Share on other sites More sharing options...
trzanko Posted August 13, 2017 Share Posted August 13, 2017 The copy to points node accepts an orient quaternion and also a vector "matrix" as @N for z-axis, v@up for y-axis, v@side for x-axis. if these are packed objects you can set the transform primintrinsic to a matrix3 comprised of the v@side,v@up,@N matrix Quote Link to comment Share on other sites More sharing options...
