defc0n1 Posted August 9, 2017 Share Posted August 9, 2017 Hey guys I have a python library that does not work well in the Houdini python environment. However, it works fine in my system environment. Is there a way to run a .py file from disk from a python node? If yes, can it be made to use the system environment? Thanks! Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted August 11, 2017 Share Posted August 11, 2017 No matter where you run python code from, you're using Houdini's embedded Python interpreter. Quote Link to comment Share on other sites More sharing options...
