store point number in array
mrcoolmen
1 hour ago, Hartman- said:
What you want to do here is to run a wrangle as a detail (so it will only run once) and then loop through the points. This way, you can build upon the array and then set the array to each point. See attached file!
Create_Point_Array.hiplc
Hey Hartman,
Just a follow up question, the idea of append(points,i) it make sense to me.
however, i tried to append a custom attribute than it return me a weird result such as
  append(points,@id)
den it does not really work, just curious wat did i do wrong?
@mrcoolmen
you are running over the detail, so append(points,@id) looks for @id as a detail attribute, you may need to read @ from point first, and then append
for (int i=0; i<@numpt; i++) {
    int id = point(0,"id",i);
    append(points, id);
@Hartman-
please, why is this line necessary? and why is it outside the loop?
addpointattrib(0, "allpoints", points);
to write point numbers to an array in detail mode you could just do:
i[]@points = expandpointgroup(@OpInput1, "!");
or in point mode:
int point[] = array(@ptnum);
setdetailattrib(geoself(), "points", point, "append");
however, depending on the number of points, the second method might be slightly slower compared to iterating over points in detail mode ...
  • Like 4
or in point mode:
Those are much simpler than mine, now I'm learning!
6 hours ago, ikoon said:
@mrcoolmen
    append(points, id);
@Hartman-
It's what made sense to me at the time, it works but I should probably revisit my logic. Was a bit tired when I made the example!
