rings artifacts in meshing particles flip houdini
rashwan
Hey all
iam trying to mesh high viscosity particle flip , but the mesh is creating this wierd rings , i have tried remesh therings gone but the mesh behave the same , the problem is when i shading this mesh with high reflected it appear in render .
any help please
and thanks
First thing i would do would be to put adaptivity to zero in the particle_fluid>particlefluidsurface1, in surfacing tab, output. This will allow a more precise mesh from one frame to another, the adaptivity can produce some vibrations. Still in the same node, if you want to add some wireframe, you can have a lower Particle Separation or a smaller Voxel Scale. Those weird rings will still be there, but you shouldn't notice in rendering.
