Vector Displacement bake geometry
You could use the Attribute from Map SOP ... export to Cd, Export Attribute: Cd
http://www.sidefx.com/docs/houdini/nodes/sop/attribfrommap
Normals to points:
http://www.sidefx.com/docs/houdini/nodes/sop/normal
Then change point positions in the Attribute Wrangle:
@P += @Cd * @N * chf("multiplier");   //press the "little slider" button on the right side of the snippet area, to generate input
The attribute name does not have to be "Cd". Cd is colour diffuse, so it sets also point colours.
Edited by ikoon
