Evaluating Expressions From Hdk
I was just curious, if anyone knew a way to evaluate an expression from within the hdk.
for instance, if I have a string input parameter on a custom SOP that is "rand(0)" , how would
I evaluate it and use it in my cook method.
thanks,
jeff
thanks,
jeff
20540[/snapback]
In OP/OP_Parameters.h there are methods like evalString.
As long as your expression is formated correctly it should evaluate the parameter.
`rand("0")`
If.....you want to pass a actual string to your custom SOP and then evaluate that expression internally....then I think you can use CMD_Manager::execute() to evalute the expression.
Ie:
UT_String foo("echo `");
foo += myExpression;
foo += "`"';
CMD_Manager::execute(foo);
There is probably a better way.......
Ed?
You could use CH_Manager::evaluate(). Local variables won't work though.
eg. OPgetDirector()->getManager()->evaluate("rand(0)");
20545[/snapback]
thanks... that worked great!!!!!
one problem though, which i expected is that when i call rand(0) and a set of points, all the random values are exactly the same, b/c the seed is the same.
Is there a good way to either expose the $PT variable.
I can just override "$PT" by replacing it with whatever i want, but it seems wrong to do it this way.
thanks
jeff higgins
Where are you calling this? If you're within the cook codepath of a SOP, then you could try:
evaluate(my_expr, current_time, getChannels()).
This is all assuming that you've already set up use of local variables of course. See the SOP_Flatten.C in the HDK examples.
  • 2 months later...
20545[/snapback]
revisting this after a while, I wouldn't mind being able to get local variables working.
would you know how to get this working.
The CH_Collection* local on the evaluate method looks like what i should be using, but
so far my attempts have been fruitless.
i was looking at an older SOP_Flatten.C (ala v7), i still seem to be having a problem.
maybe i can explain more, because maybe local variables isn't really what i want.
i want a custom sop the will assign attributes based on an expression using other variables.
I will need to do more with them after this is established, which will require the use of the HDK.
so if in my network i have three point attribs X, Y, Z with (local variables $X, $Y, $Z), then I want to be able to have in my custom op set Z to an expression like sqrt($X*$X+$Y*$Y).
So my custom sop will have to iterate over all of the points and evaluate the string "sqrt($X*$X+$Y*$Y)".
I was thinking evalFloat would be what i need, but it doesn't seem to be working for me!
Thanks!
evalFloat() should work provided you've setup the use of variables correctly. Here's the relevant code portions from SOP_Flatten.C.
eg. you need to do this first:
setVariableOrder(3, 2, 0, 1);
myCurGdp[0] = gdp;
setupLocalVars();
Then you need to do this for each point prior to calling evalFloat():
myCurPt[0] = ppt;
And finally, clean up when done:
resetLocalVarRefs();
myCurGdp[0] = gdp;
setupLocalVars();
myCurPt[0] = ppt;
22409[/snapback]
using the follow in my cook method:
UT_String a = "$PT";
UT_String b = "rand($PT)";
myCurGdp[0] = gdp;
setupLocalVars();
GEO_Point* ppt;
FOR_ALL_GPOINTS(gdp, ppt)
myCurPt[0] = ppt;
cout << evalFloat( a, 0, context.myTime ) << " --> "
<< evalFloat( b, 0, context.myTime ) << endl;
but i would get the following error for every point in my grid
evalFloat: Invalid parameter name $PT
0 --> core_berkleydb1 evalFloat: Invalid parameter name rand($PT)
j.h.
Surely thats because you are passing an "actual"  expression as a string rather than the name of a parameter which the user may have typed a parameter string into.
Are you doing this just to test the result or because you want to always evaluate rand($PT)?
22470[/snapback]
i'm doing this to test the result. I want to the user to be able to enter any valid expression as a string,
and then in my custom node i want to be able evaluate it for every point.
ideally i would have 2 such expressions (key, value) which would store values to a berkleydb.
