Problems About Dops Expressions
hammer
Hi everyone,
I am having problems of using dopsnumrecords() in sops, It will display probably in the field but it won't update the parameter.
e.g. I use the dopnumrecords("/obj/dopnet1", 3, "Impacts", "Impacts") to driven the Y translation of a grid. I can tell it's getting the correct value when I click on the parameter name, but the grid just won't move at all.
It seems that Dops expression will only update the SOP parameter at the frame that it(the exp) was created and I remember I used the exactly same expression on the alpha version of DOPs and it was working fine... ...any idea for this one?
thx
Hammer Chu
M.. that's a typing mistake :P (and I've fixed it in my first post). Anyway I can see the number of records change at each frame (and they are correct) when I click on the parameter name. It's just the Sops that didn't get updated and animated.
