Screenglow VFX Posted September 18, 2017 Share Posted September 18, 2017 Hi guys, I have this problem that I can't fix: I have redshift and arnold installed (Redshift working perfectly).When env file contains path to arnold and houdini,only redshift is working. If I remove redshift lines from env file ,arnold apear in the menu but give traceback errors and stuff ! Do you know what is wrong here? env file : # Example: # # HOUDINI_NO_SPLASH = 1 HOUDINI_USE_HFS_PYTHON = 1 # htoa config start PATH = "$PATH;C:\Users\screenglow\htoa\htoa-2.1.3_rcca6014_houdini-16.0.705\htoa-2.1.3_rcca6014_houdini-16.0.705\scripts\bin" HOUDINI_PATH = "C:\Users\screenglow\htoa\htoa-2.1.3_rcca6014_houdini-16.0.705\htoa-2.1.3_rcca6014_houdini-16.0.705;&" # htoa config end HOUDINI_DSO_ERROR = 2 PATH = "C:/ProgramData/Redshift/bin;$PATH" HOUDINI_PATH = "C:/ProgramData/Redshift/Plugins/Houdini/16.0.705;&" Thank you. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 18, 2017 Share Posted September 18, 2017 you're overwriting the arnold stuff with the redshift path & Houdini path. try something like adding a : HOUDINI_PATH = "C:\Users\screenglow\htoa\htoa-2.1.3_rcca6014_houdini-16.0.705\htoa-2.1.3_rcca6014_houdini-16.0.705;&:C:\Users\screenglow\htoa\htoa-2.1.3_rcca6014_houdini-16.0.705\htoa-2.1.3_rcca6014_houdini-16.0.705;&" Ref: https://stackoverflow.com/questions/21131590/how-to-add-multiple-path-in-path-variable-linux Quote Link to comment Share on other sites More sharing options...
p2or Posted September 19, 2017 Share Posted September 19, 2017 (edited) Agree with @marty. In case there are multiple assignments per variable (HOUDINI_PATH, PATH, etc.) only the entries of last one will registered properly (variable shadowing). If HOUDINI_PATH already has an entry, you can concatenate the paths separated by a semicolon(;) on Windows. Please note that even on a Windows machine forward slashes are required. Also make sure that all paths are valid and there is no white space between each path and the separator(;). Arnold, Redshift & Renderman example: # # Houdini Environment Settings - houdini.env # # ... PATH = "$PATH;C:/ProgramData/Redshift/bin;C:/Users/<USER_NAME>/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705/scripts/bin;C:/Program Files/Pixar/RenderManProServer-21.5/bin;&" HOUDINI_PATH = "C:/ProgramData/Redshift/Plugins/Houdini/16.0.557;C:/Users/<USER_NAME>/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705;&" Edited September 19, 2017 by p2or 2 1 Quote Link to comment Share on other sites More sharing options...
