evanrudefx Posted September 20, 2017 Share Posted September 20, 2017 Hey, I have a question about re-timing a cache. I don't need interpolation to slow it down, but rather I want the cache to play at normal speed, then gradually speed up. then go back to normal speed. I looked at time warp, but it only seems to remap the whole input and output rather than letting you gradually speed up or gradually slow down. How do I do this? Thanks Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted September 20, 2017 Author Share Posted September 20, 2017 hmm, I found a way by using time shift by frame method and manually keying values. Is there another better way to do it? Quote Link to comment Share on other sites More sharing options...
ikoon Posted September 21, 2017 Share Posted September 21, 2017 Well, other approach could be: - have a "speed" detail attribute, animate it (value of 1 would be the default speed) - then use Area CHOP to calculate the appropriate shifted frame number: http://www.sidefx.com/docs/houdini/nodes/chop/area But still you need Timeshift and keyframes for the "speed" attribute :-/ it just may be convenient for some kind of effecs. Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted September 21, 2017 Author Share Posted September 21, 2017 alright, thanks, I will check this out Quote Link to comment Share on other sites More sharing options...
rod.vfx.td Posted September 21, 2017 Share Posted September 21, 2017 timeshift with key on channel is way to go! or you can use timeshift with a expression $F with a multiplier by a spare float parameters, it is easy to control if you not need exact frame control. 1 Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted September 27, 2017 Author Share Posted September 27, 2017 On 9/21/2017 at 3:36 PM, rod.vfx.td said: timeshift with key on channel is way to go! or you can use timeshift with a expression $F with a multiplier by a spare float parameters, it is easy to control if you not need exact frame control. thanks! Quote Link to comment Share on other sites More sharing options...
