Xcapitanx Posted October 13, 2017 Share Posted October 13, 2017 Hello, I am new in houdini Question is that how can i create Tile System in houdini? For example i want to create tiled brick,tiled stones,tiled floor and etc..to bake maps.like substance designer system but in SOP! Like Wrap in zbrush! Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted October 18, 2017 Share Posted October 18, 2017 You can do it in the material, and cops contexts a bit easier than sops. Cops has less nodes than in the material context, and the material context you need to render. As for sops in h16 as long as you set it up in square format, you can use the sop import to write out via cops. Or you can render it out with orthographic camera in rops. They each have their strengths and weaknesses. Look into the copy sop for most tiling operations. Good luck on your Houdini Journey. Quote Link to comment Share on other sites More sharing options...
