installing Scipy houdini 16, windows 10 problem
DougStruthers
Thanks.  That worked.
There is a secondary problem when I launch Houdini I get a popup:
Runtime Error:  Program: C:\Program Fil
R6034
An application has made an attempt to load the  C runtime library incorrectly
zPlease contac the applications support team for more i nformation
  • 4 months later...
  • 3 weeks later...
R6034
You can fix this by renaming all files called msvcr90.dll to something else in the houdini docs folder. I'm not sure if that will break any libraries though...
