CliveLlewellyn Posted November 22, 2017 Share Posted November 22, 2017 (edited) Hi Guys, I am currently working on a shot where I need to simulate an object falling slowly through deep water whilst bleeding (The more blood the better). Initially I began with a pretty simple setup, An emissive object, a collision object and a divergence volume which is being used for expansion. The problem I am running into is that I need the smoke to continually expand, whilst becoming more diffused and transparent, but to always remain in the sim. So I have disabled dissipation as I don't want to lose density, but this leaves me with a dense volume which isn't transparent or diffused. I would like the density that is in the sim to have an aged based blurring. I did try to achieve this with a gas dissipate and heat field but this still wasn't right. I have also spent time trying to tweak the pyro shader to achieve the desired effect but I am not having much luck. Below is an example of the look I am trying to achieve. Between 0:21 and 0:34 Any advice will be greatly appreciated. Many thanks, Clive Blood_in_water_odforce.hip Edited November 25, 2017 by CliveLlewellyn 1 Quote Link to comment Share on other sites More sharing options...
