POP inherit point normal from passing a point
Hi Odforce.
I have POPs moving past a point and I want the stream to inherit and keep the points normal after passing.
I thought this would be a straight forward pcopen() case, but I cant get it to keep the normal. It's only there for as long as it is within the search radius.
I've tried a few different things in vex. wrapping it in an If statement instead of while, but to no avail.
Edit: I should maybe mention that I'm in SOP right after importing from a DOP.
Tried to make it work in POP wrangle but had no luck there either.
Thanks,
Bastian
Edited by bastianlstrube
Try this in a popwrangle inside the popnet.
if(@n2 == 0)
        float radius = chf("radius");
        int maxpts = chi("maxpts");
        int handle = pcopen(1, "P", @P, radius, maxpts);
        v@n2 = pcfilter(handle, "N");
        v@N = @n2;
