executing python from within hip file
newbee
I want to run my python code from object level of the houdini node network.
basically if i pass my scene file to another person, they should be able to run the code from from within hip file's node network itself
instead of passing on a separate shelf button
I tried using the python node on the object level but it doesn't have an execute option that the other person can use.
any one has an idea?
