Which attribute has the same effect as roll on the sweep node ?
AntoineSfx
I need to tweak a portion of the sweep node to correct the roll of the cross section curve. How may I do this ?
I tried to set up in a attribute wrangle but it's not working as expected. I know how to set a ramp parameter so that I can tweak it on a per point basis, but I can't get it to work with a fixed angle for the whole sweep.
